V
vetinry
Hello all
Once again, I'm hoping that you might be able to give me a bit of advice
It's been a few weeks now since I last posted to the site. In the meantime, I've been having a pretty dramatic overhaul of the central heating system and domestic water.
We've changed from a gravity fed "Y" plan system to a unvented "S" Plan plus central heating and a completely seperate unvented Ecocent supplying the hot water.
The plumber has done a really tidy job on the pipework, but he doesn't seem quite so switched on when it comes to the technical side and trying to get the heating system up and running has presented a few problems.
There are now 3 CH zones, 1 for the UFH in the Kitchen, 1 for downstairs and 1 for upstairs.
The boiler is outside and 28mm pipe runs to the back of the old airing cupboard (Hot water cylinder now in garage) where it goes through a Grundfos 15-60 pump, changes to 22mm pipework and to the 3 2 port valves. Each of these is switched by its own Honeywell CM907 programmable thermostat.
The UFH circuit runs to the utility room and supplies a continental manifold with its own grundfos 25-60 pump.
The upstairs circuit is fairly small (2 rooms with thermal skirting boards, 1 radiator in hallway and 1 or 2 radiators in bathroom, not yet installed) and seems to heat up no problems at all.
The downstairs circuit has 11 radiators and the main circuit runs around the upstairs bedrooms (bungalow extended upstairs) and has 4 drops to different radiators. The final 3 radiators are right at the end of the run and we've been having problems getting any heat into them.
Now that there isn't a primary radiator circuit, there is also an ABV fitted immediately after the pump.
The plumber has been trying all sorts of different things like swapping the pump because he thinks that the one I have isn't big enough, and yesterday we changed all of the lockshield valves and the old Honeywell TRVs with Drayton TRV4s (some of the radiators didn't switch off previously) - it's felt a bit like clutching at straws.
So today, I went to Maplins and bought a infrared thermometer to try and balance the circuit a little bit more scientifically. I hadn't realised that each radiator should have such a large temperature drop between flow and return.
With the pump running on level 3 and all TRVs and lockshields fully open, I did begin to get heat into all of the radiators but the final 3 were only luke warm.
I also found it really difficult to reduce the flow in the first radiators on the circuit sufficiently to create an 11 degree drop.
So then I switched to position 2 on the pump and then found it easy to balance all of the radiators apart from the last 3. They were pretty hot and flow temperature was 70 degrees, but the temperature in the return pipe was only 45 degrees - does that mean that not sufficient hot water is getting to the radiators.
Questions:
How important is the pump speed - will the system heat up more quickly on level 3, and should I try harder to reduce the flow through the earlier radiators on the circuit to see if better flow gets to the final radiators.
What is the importance of achieving a temperature drop over the radiators - is this how they work most efficiently?
It would be possible to re plumb the system so that the pipe run to the final 3 radiators was only about 10 metres (currently it's about double that from the 4th last radiator in the system).
Why do grundfos domestic pumps only have 15mm bore, and is this important. Most of the system is either 28mm or 22mm and it seems strange that the flow is restricted so much through the pump. The pump on the UFH is a 25-60 but I know whether this would be any better)
Is the pump simply not big enough for the house - total floor area is approx 300 sq metres but the pump is the same one as being used previously - 2 of the rooms have had radiators replaced by thermal skirting, and 2 of the rooms downstairs are now one room with UFH.
Finally, the auto bypass valve (Honeywell DU145) appears to have flow through it even when all of the system is running and TRVs open. I looked earlier and it appeared to be set on 6 - I tried to adjust it (loosing the screw) but as the outer red dial rotated, so did the internal black on with the numbers on - should this happen, and without knowing the minimum flow rate for my boiler (a boulter camray 5), how do I know how to set it (in fact, how do I set it, or is it broken?)
Sorry about all of the questions. It feels like I'm almost done - just want to get these final things sorted
Thanks in anticipation
Steve
Questions:
Steve
