Discuss Need advice on how to turn off cold water value to washing machine in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I need to disconnect my washing machine for several days however i am confused on how to turn off the cold water flow to the washing machine. I have taken a photo. There is no lever from what i can see. Do anyone know what i need to do with this?
Reactions: Dan
The plastic lever has fallen off , you should be able to turn it off with a pair of grips or pliers
Thank you! I took a pair a pliers there now and it is letting me turn it. It is a very difficult location to turn. Do you know if i can get a spare lever in screwfix or a plumbing store? Not sure what i need to purchase.
1. Sometimes, particularly on cheap valves, the plastic lever comes so close to the nylon nut at the end of the washing machine hose that the nut cannot be done up tightly enough, and so it leaks.
2. You could measure the width across the flats of the valve stem (the brass bit) and buy a cheap open-ended spanner of the correct size. Tie a bit of string to the spanner and the pipework and it is there next time you need it.
Reply to Need advice on how to turn off cold water value to washing machine in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, all. I have a leak problem behind the washing machine. It's a pipe that is leaking directly into a drain. It used to drip but now is leaking a...
Pritesh Patel
R
Hi, I’ve recently had my washing machine connected however the chap who installed it said the water inlet pipe connected has a larger head thus...
Morning. I have a leak. It’s coming from the connector pipe….the picture shows the pipe. It is a cold water pipe going in to the back of my...
I recently read a post / comment whereby there was a recommendation that if you are away from your home more than 24 hours, then you should turn...
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On...
