Discuss netaheat 6/10 change in the Plumbing Jobs | The Job-board area at PlumbersForums.net
wildcard
cust has a 6/10 fitted & flued to the right as you look at it which i need to change.Can anyone recommend a boiler where the flue hole needs little cutting away.The n/heat flue is the round type terminal not the square outlet.
Really im looking for a quick swap over.
If the flue goes to the right you will find its too close to the wall the boiler is sat on for most modern boilers. The worcester ri is 127mm to the centre of the flur to the side and can be run at an angle to reduce the amount of chopping out you have to do.
Hope this helps
Quick swap! How long to core a hole? 10 minutes including getting the gear from the van and putting it back plus 10 minutes if you have a *** while your doing it, to fill the other hole up.
I think i'd rather offer my preferred choice of boiler than stick something in to suit a hole in the wall.
unless its 23 inch solid stone
Add an extra 10 minutes if you have the right gear Mark :wink:
27" up here
had one last week,3 hours with the kango and makita sds max,had to rebuild the kango it overheated and the guts fell out
Reply to netaheat 6/10 change in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I want to replace the old single panel rad in the bedroom with a K2 double panel Stelrad one. I think I'm OK in general and relatively...
The rusty bit with a hole at the top looks quite old, feels flimsy, and is a single skin 100mm x 400mm. The boiler has a 600mm new pipe rising...
Hello all, I bought my house last year and recently had a couple of radiators swapped for modern triple columns. Since they were installed they...
3K
Hi all, looking for some advice please. So I've got a 25 year old Ideal classic NF40 boiler. We live in a naturally warm house so only have the...
1K
M
Hope this is in the right forum. We've a utility room radiator with 10mm pipework; fitted about 6 years ago it has a BOSS TRV which has failed...
3K
