Discuss New Analyser in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dcollie87
Hi everyone,
Time to get a new Analyser. Have used a Kane and then an Anton in the past. I found the Kane would take too long to purge and the Anton would have to be sent off for repairs more frequently then the Kane… Has anyone got experience with Testo or any others? Preferably someone that has also used others brands for comparison?
David
Purge time on the Kane has never been an issue. Just turn it on as you are stripping the boiler down. And if you only need Mano mode hold on and enter and you can use everything on it other then performance testing
Testo next only thing is the hoses on testo need that stupid plug
testo cost too much, Kan anytime for value, servicing costs and warranty
Didn't know this, thanks!
I've had the Kane for 4 years now, all it's had is the annual calibration (costs £100 of the top of my head). The only issue I have with it is it takes a while to react to changes in CO2, the Anton 'refreshes' much more often so is easier to make adjustment.
Testo 330 i use , expensive to buy , calibration same as rest far superior machine to the kane as ive used both,
Purge time for testo machine when switching on is 30 secs otherwise b4 a test is 10seconds
My two pence is that Kane's are great for domestic but bad for industrial.
Testo have a new industrial ones the 340 and the 350 but they are soley for industrial,
I'm an employee so use what I'm given, but as you have asked a EiUK rasi 700 if I was to be paying my own dollar.
Going to request a new analyser when I'm in office next time I'm running about with two Kane's because I can't trust them when checking combustion on industrial gear.
Other work mates using rasi and testo's and have less issues getting combustion checks than me.
I've only ever used a Kane over d years, but they've never really let me down. Only ever had probs with older 1's maybe 10 15 years ago. The huge 1's in d cases 9001 or 9003 I think. Get em services and calibrated. Am very happy with them. Price wise they're pretty good.
Thats all I can say about them.
Purge time shouldn't matter, you are supposed to purge outside, so switch it on when you take it out the van and it will be ready by the time you get to the boiler
I work in Middlesbrough some times there is less CO in the flue system than outside !
Reply to New Analyser in the Plumbing Jobs | The Job-board area at PlumbersForums.net
