Discuss New and wanting help. Air in the system? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
Got a new house and has a power shower fitted.
A few weeks after moving in the shower started to struggle, like water wasn’t coming through.
Got a “Triton power shower” but the problem still there. Sometimes worked a little better and sometimes didn’t but always struggling , sounded like an engine when stationary but still pressing on the pedal.
Got a plumber and he fitted a valve in the loft to release the air.
Problem still there and he advise to replace the shower was it was faulty.
Got a new shower today and before I installed it done some tests:
- try to bleed the radiator in the bathroom that it’s connected to the hot water system (at least it’s what I think), no luck.
- check the water coming to the shower pipes without anything attached and clearly can be seen struggling.
- used the trick to block the hot water in the kitchen and while blocked open the cold, no luck.
Fitted the new shower but still doesn’t work.
Tried to let it run without the shower head and it does run (struggles) but 10 minutes later wife goes to have shower and doesn’t work, goes dry.
I have water tank in the loft that feed the hot water tank, the locking thing works.
In the kitchen there is a boiler that heats the water and does the radiators.
It doesn’t have a Surrey or Sussex flange but after discussing it with the plumber he says the way it is should work.
Any help would be welcome as I am relying on a jug for shower as the other shower in the bath has no pressure.
Can we double check , the shower is defo a power shower . ie it has an internal pump ? And uses tank fed cold and hot water from the cylinder.
Not sure myself pal , a power shower should not be mains fed , it should be fed by a tank ( cold from tank in loft , hot by the cylinder )
Can you confirm that the cold to the shower is a separate pipe all the way to the cylinder?
Also, you say there is no flange to the cylinder. You do, however, have a separate pipe all the way from the shower to the cylinder for the hot? And how does this connect to the cylinder? Can you photo or sketch it for us?
Hot comes from the cylinder as seen on the photo. When in the loft, there is a cold feet that comes from the tank and runs parallel with the hot into the power shower.
It's pulling air in from that
Ok I think I am getting somewhere.
As do only thing that changed was the Nest and having a schedule to come on 6-7am and 17-18pm.
So yesterday set the boiler to always on 24hr ...
And the power shower worked again and this morning still working.
I am confused ‍♂️
Why the power shower only works when always It’s always on???
I'm out, this guys a bodger and shouldn't be going anywhere near it.
What a bell end you are , I was just worried that I wasn’t making much sense and today started a new one but on the newbie forum and thought I would get more responde on the plumbing one. I can’t find an option to delete.
Thanks for nothing and your last advice was crap anyway . Get another plumber , no Rubbish Sherlock .
Reply to New and wanting help. Air in the system? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
