Discuss New and wanting help. Air in the system? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can I have a picture of the actual
Shower please
Would say that it is either the fact the shower can not detect the pressure drop in the supply to switch the pump on or it keeps air locking in the loft? Shower with integral pumps don’t really like up and over pipework.
What a bell end you are , I was just worried that I wasn’t making much sense and today started a new one but on the newbie forum and thought I would get more responde on the plumbing one. I can’t find an option to delete.
Thanks for nothing and your last advice was crap anyway . Get another plumber , no **** Sherlock .
You're welcome, btw it should've been the first advice I gave you since it's clear you know very little...
"- try to bleed the radiator in the bathroom that it’s connected to the hot water system (at least it’s what I think), no luck."
Don't if you seen what I posted earlier :
"So I tried different things and found out that if the boiler is left on 24hr (I say on but I believe comes on every time the stat ask for more heat) the shower works.
If is set to come on a couple of hours a day, shower won't work,
to be clear shower works but struggles as very little hot water comes through."
I have a nest where I set the schedules.
When you say Little hot water? Do you mean temperature or flow?
Water - air - water - air - water - air - air
And you can hear the shower struggling because the hot water it’s not getting to the shower. If I turn the dial to more cold, water comes out but still struggles as the won’t let you have just cold.
My issue is, I can’t have the tank heating up only 2/3 hours a day, needs to be always on for it to work.
Fit a standard shower and install a shower pump if the cold tank is big enough
Or go electric
So the shower isn’t next to the cupboard?
As you come out on the right but it’s the opposite corner on the hall.
Correct me if I am wrong but once the water heats, goes to the top of the cylinder and comes out when I open the tap and the hot/steam/pressure helps it flow.
But the tank it’s only on for a a couple of hours and doesn’t get hot enough ???
Would a Surrey or Essex flange help ?
Probably not. If it was my house I would do what @ShaunCorbs said and fit a normal mixer shower and an external pump in the cupboard. The shower probably hasn’t worked correctly since it was fitted.
I actually thought Of it but as I am re-doing the bathroom at a later stage and wanted to get it working .
But i believe will need a bigger tank as the one I have it’s 25 gallon .
Thanks .
Reply to New and wanting help. Air in the system? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is unvented and pressurised. The cold water feed into this cylinder is from the attic tank, not the mains as I turned off the mains stopcock to see if hot...
A
Hey, here goes and I hope it works.. never used one of these before! I have a Sagittarius Ergo mixer shower min bar of pressure required 1 bar. Connect to this is a 1.5 bar Ora Salamander pump for a positive head, this was connected by a plumber of course and we’ve had it all rigged up...
I had a plumber fit a new mono block kitchen tap. The water runs very slowly now. Also, not sure if this is to do with it, but my hot water doesn’t get as hot as it did with my old tap. Anyone help?
Plumber had fitted a new mono kitchen tap. The hot water takes ages to get hot if at all. The on lever hadn’t much turn on it and it’s at full throttle. Also when I point tap to bowl with fairy liquid in, it doesn’t have enough power to make bubbles
Hi, I'm looking for a water pump to pump water from a storage tank at a constant 3 bar pressure. It's at a campsite I run that's at the bottom of a long, steep hill. We struggle with very high and often fluctuating (around 7 bar) water pressure, which wreaks havoc with our water heaters. I've...
