Discuss New boiler fitted - light visible around pipes going to outside. in the Central Heating Forum area at PlumbersForums.net
G
George123
Hi, had a new boiler fitted, didn’t notice at the time of fitting. you can see daylight around the overflow and condensate pipe, not an issue at present but should this be sealed to stop cold air coming in?
Reply to New boiler fitted - light visible around pipes going to outside. in the Central Heating Forum area at PlumbersForums.net
H
I need some help and advice with a boiler issue. We have F29 and then F29 appearing on our new boiler. This happened after few days where water...
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a...
Hi, I've not posted for a while, not a plumber, but a keen DIYer who likes to try and do things without bodging if I can. Basically I'm wanting to...
Hello, bit of a noob question but would someone be able to help me to understand the pipes coming off our boiler. It's a Grant oil combi boiler...
Hi, I am probably being unduly paranoid here but I noticed under our kitchen sink that there is some corrosion evident on a small section of...
