- Messages
- 10
Discuss New boiler - questionable install in the Gas Engineers Forum area at PlumbersForums.net
It looks like this externally (got picture on line as im not at home at the moment)
And yes checked the spur. There is no electrics in the house other than temporary extension leads until rewire starts. Thats why it was in the scopes of work for the boiler installSilly question maybe... what do i need to check with the vent? TIA
If that’s definite and it’s not sealed with cement and vented fully through then it’s been installed as at risk imo. It might be worth a call to gas safe if this is found to be true.It looks like this externally (got picture on line as im not at home at the moment)
I'd suggest even if it's been sealed up, it's too close. Not sure the gas regs would consider anything other than the possibility that the vent could pass air, so long as it it is there at all. (Waiting to get shot down by the forum gas installers if this assumption is wrong).No not a silly question at all. Basically check the vent on the other side of the wall, if it’s vented, then it’s too close.
True. Worth checking the quote. It may say 'connect to existing electrical installation'. But logically the extension lead plugs in somewhere.If there's no wiring in house then how are they supposed to wire it in?
I think it’s acceptable as it’s no different from a brick, et al. The flue must be 300mm away from an opening to the building, other regs do apply but not in this scenario.I'd suggest even if it's been sealed up, it's too close. Not sure the gas regs would consider anything other than the possibility that the vent could pass air, so long as it it is there at all. (Waiting to get shot down by the forum gas installers if this assumption is wrong).
If sealed with mortar, I'd agree. But what if a DIYer had bunged silicone in it in the past to stop the draught? Surely still a vent? We had a recent discussion about what if a window pane is replaced with a bit of hardyboard and I thought we concluded it was still a window that could easily be turned back into a window. Hence my train of thought. Not saying I'm sure, mind you.I think it’s acceptable as it’s no different from a brick, et al. The flue must be 300mm away from an opening to the building, other regs do apply but not in this scenario.
Quote stupilates installing supply for fused spur.True. Worth checking the quote. It may say 'connect to existing electrical installation'. But logically the extension lead plugs in somewhere.
OP - how is the extension lead plugged in?
The pipework routed outside looks to be an overpressure or condensate pipe and is probably correct to go outside (you can always post up a photo for us).
They removed the toilet without it being agreed?!
Just another question. If this was sealed up, would I need a vent in the bathroom with it having a boiler in?I'd be happy if it was well sealed with mortar (no loose bits). I'd also seal internally but probably wouldn't pull it up on service if it wasn't.
Reply to New boiler - questionable install in the Gas Engineers Forum area at PlumbersForums.net
