Discuss New combination PRV is humming loudly in the Australia area at PlumbersForums.net
Hi, I have just replaced the combination pressure reducing valve on the inlet to my unvented got water cylinder. The new valve is exactly the same model as the old valve, but hums very loudly when any hot tap is turned on. The only time there is no humming is when a tap is fully open. You can feel the valve vibrating when the water is running.
The valve is a Heatrae Sadia Santon 95605022 Premier Plus Cold Water Combination Valve. Any suggestions as to the issue, or if it is just a faulty valve? Many thanks
You really should not be replacing these safety devices unless you are a G3 qualified engineer there are other things to check vibrations are sometimes caused by restrictions within the combination valve . Kop
The old valve had failed and was releasing constantly from the cylinder side. The expansion vessel had the correct charge, and my plumber diagnosed the issue as being the valve.
How did you check the function of new valve?
Plumber might have misdiagnosed your problem or your new combination valve is faulty.
Does your plumber have the G3 unvented qualification?
You need to call him to check everything and to replace any components.
Check his qualifications if in doubt, but it should be on any service paperwork for the yearly service to keep unit working properly and safe.
Reply to New combination PRV is humming loudly in the Australia area at PlumbersForums.net
Hi, I’m having issues with cold water to multiple outlets. Taps, showers, toilets cold water is fine at the kitchen sink. The hot water system is...
2K
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
Hopefully someone can point me in the right direction. Before I start I am G3 qualified. As per usual I was asked to rectify a leak on a...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper...
