Discuss New gas cooker - electric cable running behind... in the Gas Engineers Forum area at PlumbersForums.net
We are getting a new gas cooker installed on Sunday. The existing one is over 25 years old, as such I'm having to do some prep to make sure it's ok to install (remove wallpaper from the hot zone for one).
In looking behind the existing cooker I have noticed there appears to be a twin and earth cable running along the skirting board.
I don't have time to get this chased into a wall before the cooker comes.
Will it be ok to leave as is? Will it need enclosing in trunking?
Note it is NOT a 32A cable, we have no electric cooker circuit at all.
They could ark or spark if damaged across to the gas pipe
also when breakers trip there a small arc/spark let off
@Murdoch , without baffling an old plumber with electrical silence , why do we keep cables and Cu’s away from gas pipes ? .
Thank you
good question really - but separation is sensible for both services ... you could ask the powers that make the rules but I suspect they won’t give a straight answer to a straight question
but it’s best to keep taps away from above any electrical assembly
Yes obviously knew and understand that but I once read something about an electrical field ( may not be just right ) what could damage / electrically corrode the pipe , @Murdoch , any thoughts or was I dreaming ?
The twin warp field increases the risk of Ohms correction sending a switched live down the graphene spline. This will stop your inline scale reducer from utilising its nanobots. Because we all know how good they are.
But that's just how I heard it.
I don't know how likely it would be, but yes, electromagnetic fields can cause electrolysis to happen.
Thats the one
Reply to New gas cooker - electric cable running behind... in the Gas Engineers Forum area at PlumbersForums.net
Hi, I'm wondering if anyone can help with a query. We have recently had a new kitchen installed and are arranging for our freestanding gas cooker...
Hi, We're changing our old electric range cooker for (hopefully) a dual fuel (electric oven/gas hob) range cooker. We have a pantry room directly...
2K
E
I reckon if I did a survey of 100 heating engineers, asking what would they recommend for heating a granny annexe being built onto the side of my...
eco-heating options
E
    • Informative
Why am I not surprised? Britain’s gas network still using engines from 1960s RAF fighter jets Ageing aircraft turbines will cost millions to...
I currently live in a 4 bed end of terrace victorian house, with 11 radiators and two towel rails. Currently have installed a 6kw potterton gold...
2K
