Discuss New Ideal system boiler - Keeps losing pressure in the Central Heating Forum area at PlumbersForums.net
I had a new ideal S32 Vogue boiler installed recnenlty. Its a system boiler. So i have a hot water cyclinder with a expension vessel to it.
I keep losing pressure and need to top up every few days. No visible leaks that i can see.....however the discharge pipe is letting out water when i have the hot water and heating on. The tundish to the hot water cylinder is also dripping when hot water is on and the guage on the cylinder is getting to 6 bar.
The pressure of the boiler seems fine and steady which makes me think its a problem with the hot water part of the system.
Is it possible an issue with the expension vessel to the hot water cylinder?
Any advice / previous experience would be helpful.
I’m a bit confused by the description.
Is the boiler losing pressure or at a steady pressure?
Any pictures of your setup?
How many radiators/ufh etc make up the system?
Reply to New Ideal system boiler - Keeps losing pressure in the Central Heating Forum area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
