Discuss New Mains pipe insulation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have been asked to replace a mains pipe from the metre along 20m run to stopcock in kitchen.
The metre is about 450mm deep (though 750mm was the min). I will run new 25mm mdpe pipe in 63mm blue ducting to the house. I was going to insulate the last bit from 750mm down to stopcock as comes up near the exterior wall.
What size thickness insulation do I need as a min to comply.:confused: As anything more than 12mm and I will have to upsize my ducting.
thanks
Ducting? thats unusual?
I dont think the regs specify a insulation thickness only it must be water proof
New water pipe is supposed to last a long time?
Got stuck in a room with the ex wife once for 7 minutes ...........................................................
THAT WAS A LONG TIME !!!!!! :eek::p;)
All relative
Reply to New Mains pipe insulation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
