Discuss New PLumbing under sink has extra bends, affect water pressure? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scorps79
We have just had new plumbing fitted underneath
the kitchen sink. Please see the photo.
Unfortunately mistakes were made and
now we have 2 new stopcocks instead of
one and also 2 extra bends in the copper
pipe.
Can anyone foresee any issues with
this? I was concerned the cold water
pressure may be reduced ...
eT5FlGpXWSCBRf4AGodMmYgGaY_wfb6dEV5FVU3ptJs=w161-h207-p-no
https://picasaweb.google.com/108107...authkey=Gv1sRgCLjko_vJh9qGgQE&feat=directlink
not pleasing to the eye, but seeing it is in 22mm pipework, I doubt you'll suffer any issues. Lever valves were used, so why fit TWO of them?
I would easily have just used the one bend. Personally, I would have pulled a 90 degree bend on the 22.
Not the nicest to look at but mains will cope with the small resistance. At least you have isolation valves . Rather have 2 than 0. So youl be fine.
Agree with the above. Cannot understand why this has occurred but shouldn't pose a problem. The pressure loss will be so minimal it will go unnoticed
Full bore lever valves have little resistance just a lazy plumber that installed it.
Hi Guys,
Thank you for the replies, I do feel better
now ...
should be a stop tap, a lever can be fitted above if you wanted a valve that turns off easier/ quicker.
I think maybe the plumb put the lowest one on in a rush maybe to get back water on then realised once cupboard installed it wouldn't be accessible by the customer so installed a second one instead of knocking the water back off.
Reply to New PLumbing under sink has extra bends, affect water pressure? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I am desperate for some help. Basically we are having our bathroom renovated. The plumber removed the units, including the sink a few days...
Deleted member 120897
I have a seemingly impossible problem. I am not a plumber but I can at least understand some of it. We have just had the Water Board inspector...
Hi everyone, I moved into a new build three bedroom, two bathroom bungalow about 2.5 years ago. Ever since we moved in there has been an issue...
6K
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution...
