Discuss new property, iFlow + navian installed incorrectly? in the Central Heating Forum area at PlumbersForums.net
I have a Navian boiler with an iFlow air system that provides air around the house via high velocity conduit. It's just over a 1 year old property and I just moved in and found the heating suboptimal.
I have had a plumber indicate the system is designed and installed incorrectly, which the builder disputes. I am filing for a warranty claim but curious if I could get some internet stranger bias or advice one way or another.
Issues:
Heating in most rooms is poor, room does not reach temperature set point on thermostat of 23c
Boiler/heating comes on and off frequently (every 20-30 mins)
No return airflow from upper level into boiler/hvac, possibly causing balancing/pressure issues
There's open ducting going from the mech room directly outside
Boiler intake not connecting to fresh air inlet
The plumber claims
the high velocity ductwork is incorrectly designed and needs to be re-done
there's leaking or missing ducts in crawlspace
gas line code violations
incomplete iFlow setup
no recirculation
pipes un-attached (pressure relief valve?)
incorrect material used (90' ptex connectors?)
Can anyone provide their opinion based on the photos and confirm the plumbers concerns?
I thought I'd replied to this. One of the flues not connected, lots of visible shoddy pipe and duct work. You don't need further confirmation about the quality of this install, it should probably be condemed.
Get it fixed and sue the builder for the cost who probably did it.
I believe I will have to go through warranty first, however it does mean the original installer would be required to remediate
Ok, the process is the same as ours in the UK in that you have to give the builder/plumber a chance to make good. That would be fine unless he denies there is a problem, does your warranty cover all outcomes in that regard?
builder sent me the iflow manual and pretty much said to spec. 2 separate plumbers and a HVAC specialist say it's a message and spectrum of work that's needed. Im pretty lost at how much this needs to get fixed
Yep agree installation issue
Reply to new property, iFlow + navian installed incorrectly? in the Central Heating Forum area at PlumbersForums.net
I
I have a Navian boiler with an iFlow air system that provides air around the house via high velocity conduit. It's just over a 1 year old property...
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler...
I have a leak in my leasehold flat in a small council 4 storey block of flats – 8 flats in total. In the corner of the bathroom is a cupboard...
3K
Hi all, Let me start by saying, my heating works fine. I only know the basics of a system, and this may well be just me and my sensitive...
3K
Interested on thoughts on this (I've also posted on another forum but thought this might be a better place to ask); Long time lurker, have...
4K
