Discuss new radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello!!
I am new in this forum just looking for friendly advice.
I am a retired electronic technician, but many years ago I was helping my bros as plumber.
My question: I am installing 2 new radiators: vertical, 3 column, size1800x200mm.
Can I use the BOE valve arrangement or must be TBOE? If BOE is used will be there any relevant loss of output.
Please help!!
GGMAN
Welcome to Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK!
Welcome to UKPlumbersForums.co.uk ggman. Thanks for introducing yourself.
hi ggman welcome to the forums personally i would use boe
steve
Hi ggman
Welcome to the forums,hope you enjoy and feel able to get involved
There will be a heat lost in output using bottom only entry for valve positions as opposed to top and bottom valve positioning,however you will have to consult manufacturers to gain precise figures
The radiators should not be too much , the towel rails output could be more significant,however some of the good quality towel rails have restrictors inside and designed taking into account bottom only entry
As regards 200*1800 towel rails ,I would like top and bottom entry if possible and believe will be much improved output
imho
Reply to new radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
