Discuss New Shower Valve, Slow drain in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
K
kevSpam
I have installed a new shower valve and shower head (the restrictor um fell out) and as a result the tub starts to fill with water. I believe this is simply a math problem of more water coming in than can drain but asking if any known options.
As a sanity check I did snake the drain and overflow pipes which do not appear clogged.
Can I change the tub shoe as mine seems to be 45 degrees which seems to be a pinch point. A larger shoe or vertical drain with p-trap possibly. Can deal with tying in the overflow piping as needed.
The other option is to add a restrictor to the shower head to balance the flow and drain.
I do like the water pressure, not going to lie.
As you say, either need to improve drainage or restrict water flow.
Put a flow limiter where the head attaches is the simplest solution. Try 12 litres per minute to start with and see how that is.
Reply to New Shower Valve, Slow drain in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
