M
Minty_Cymru
Hello all.
I'v recently moved home and we've gone from a back boiler to a combi system.
It's the first time I've ever had an experience with a combi and, although I love the convenience of it, I'm a little confused at one of the functioning states.
The combi is a Ravenheat CSI/HE 85 (model 85AaaT)
ok, so the front panel is simple, from left to right we have:
Hot Water/Heating & hot water switch (with reset)
Water Temp (with highlighted condensing mode setting)
Heating Temp (with highlighted condensing mode setting)
Timer
Power & Warning Lights
Pressure Gauge
All quite self explanatory, my confusion comes from the hot water only operation;
There is a switch on the wall next to the combi, with the switch on the power light on the combi is lit and we have hot water and if the timer is engaged or it is knocked on manually (conrolled via the timer) we also have heating. With the switch off, the light goes out and there is no hot water (obviously) however the timer is still finding power from somewhere.
Here's my question, what is the point of that switch on the wall if there is a 'water only' option on the control panel and the manual on/off/timed control only affects the heating?
Should I be knocking it on and off at the wall? Is there a danger in doing that?
Thanks!
Timer
Pressure Gauge
Thanks!
