Discuss NIBE ASHP Alarm 'low pressure warning in the Renewables area at PlumbersForums.net
What’s your system pressure eg heating ?
Should be a guage either where the hot water cylinder is maybe attached to a red vessel normally 1-4 bar
Red one is heating white is your hot water so looks like it’s time to call nibe out it’s either a sensor fault or fridge side
Many thanks, the system we have is a fighter 2015 hooked up to a water tank specially made by Copper Hot Water Cylinders - vented, unvented, thermal store - https://mcdonaldwaterstorage.com/, Nibe will only service the tank.. Apart from the white expansion tank failing we have had no problems with it for 11 years. Shal give them a ring.
Reply to NIBE ASHP Alarm 'low pressure warning in the Renewables area at PlumbersForums.net
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
I have a green star ten yrs old keeps increasing pressure, feel on off filling valve not working, drain off to recommended, but after few days...
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
