Discuss no hot water after increasing pressure to 1 bar in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Arron Lowley
combi boiler had no pressure although water was still running, anyway i got the pressure back to 1 bar using the hose that the plumber who fitted the boiler left on.... i had to do it slowly as the valve itself started leaking and now after a couple of hours theres no hot water, broken pump or what?.
hi
as you've topped the water up
have u tried to reset the boiler
got power to it
any lights showing on the front plse
if you've tried these u will have to get a gsr engineer in to resolve the issue for u , if you've done the basic things
may I ask though what make of boiler have u got plse
Reply to no hot water after increasing pressure to 1 bar in the Plumbing Jobs | The Job-board area at PlumbersForums.net
