Discuss No water flow (I think my Grundfos Alpha2L is not working) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gdad
Please can someone help. My system is 3 years old and has failed.
I suspect the pump It's the new fangled type with a posh microprocessor fitted in the head
of a water pump (how stupid is that) . I thought the rotor must be stuck so I removed the 4 alan screws
and took the motor from it's pipework (the rotor was easy to turn by hand)
when power was applied the rotor turned for a second but stopped. It would not run continuously I tried to help it
using my fingers but it was not having any. do you think the pump is faulty ??? ( electronics and water pumps dont mix)
fault code fd ideal logic 18;;;;;Grundfos Alpha2L 15-60-130
any ideas ?
thank's,
What setting was the pump on?
If on autosensing multivariable intelligent energy saving tree huggers mode it probably shut off with no water flow. (not actually tried it, just suspect it may)
It would need to be on fixed 1..11..or 111 speed to test out of it's housing.
I tried it on all the settings, It would not run . The last Grundfos pump I had ran for 32 years with no problems .
What's the fault code (if any) shown on the face of the pump?
any ideas ?
thank's,
Thank's for your time fyi
I have ordered a new pump from EBAY my house is freezing .:stooge_moe:
Reply to No water flow (I think my Grundfos Alpha2L is not working) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good afternoon we have recently had a grundfos alpha2L 15-60 130 pump fitted to our central heating system and we're experiencing an issue. Once...
1K
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
Hello all, I have a WorcesterBosch Greenstar 42CDi classic combi, which is providing DHW fine, but not heating. Was working fine in spring...
1K
Hello, First post, be gentle! Anyway, here's my issue. I have a Roca The Gap D-Trit close-couple toilet with integrated macerator in my secondary...
L
Hey everyone, I'll keep it short. Had our old system boiler replaced with a new Ideal system boiler set up. Then the problems began. First...
2K
