Discuss No water from Cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gungaabayar
Hi all
I have just changed the gate valve which stops cold water into hot water tank. and filled it from tank in loft. But no water goes to all hot water taps (including kitchen, basin and bath) from cylinder. I thought the new gate valve is stuck in closed position. and take it back ,but it is OK. Im going to put the gate valve back again and filling the cylinder . How and what do I have to do? Possible air lock on the top of the cylinder? Any idea guys,
cheers
DG
First get rid of gate valve and fit full flow leaver valve ! sounds like you have air lock in hot system, lots of ways to clear, mixer tap [Kitchen] usely works best, look on YouTube Proberly be a video showing how to do it
there is no mixer tap in this flat. separate tap both hot and cold water. thats nightmare under kitchen tap, no enough room, old pipes etc.
Also I put new service valve in the pipe of the cylinder which leads to hot water taps.
Can I take it out and let air out and put it back will cure the problem or not?
P.S. Can I use the lever valve you mentioned as a service valve in the hot water outlet of cylinder to the taps?
cheers again
Washing machine valves for hot and cold? Connect together and give it a blast for a few seconds. Watch what you are doing though.
As simon suggests above. Otherwise drain down again and open your lowest hot tap first then fill up, it often works
OK
I'm draining cylinder now . wonder why need to drain the cylinder fully. half way drain and open the lowest tap and fill it up wont work? what is the difference?
cheers
I drained the cylinder down fully and fiiled it with bath hot water tap open. It works.
Thank you very much. Saved me a lot money.
Cheers again
DG.
Glad it's sorted; but to be fair a half decent plumber could have done the job for a modest sum, not necessarily a 'lot of money' ☺
Reply to No water from Cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi There was no shut off valve on the tank feed to the hot water cylinder, and I needed to move a couple of hot water pipes, so I shut off the...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied...
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
My disabled daughter’s hot water has stopped working. It’s a relatively modern Potterton boiler with an indirect sealed hot water system and a...
Water keeps filling up my home water tank from the output valve at the bottom of the tank and not from the top of the tank Water keeps pouring in...
