Discuss No water from hot taps. in the USA area at PlumbersForums.net
It must be something to do with that valve, you had/have mains there as it topped up the system? And if a boiler problem you should still get cold water from the hot taps. Presume you have water from the cold tap. As suggests above did you remove the blue handle and turn the valve by other means?
When I took the valve off I could see the inside was chewed up, I turned it with a set of pliers and you heard the water go back in to the system. Thank you so much for your help, everything now back to normal :)
Reply to No water from hot taps. in the USA area at PlumbersForums.net
We have hot water, tank for hot water why is the hot water boiling hot from tap,and shower, We are on a schedule for hot water via our hive app...
Hello All, I wonder if you can help me? I have intermittent hot water low flow from all taps in my 4 bedroom house upstairs and downstairs. I...
M
Hi, I woke up this morning with cold water (mains) from downstairs tap but no hot water from downstairs tap, and no water at all from all the...
Mike Young
M
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
