Discuss No water from hot taps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Alex Knight
Hi all, was called out yesterday morning to a house where no water was coming out of the hot taps, kitchen sink, and upstairs bath and basin, I tried to blast out any air locks by connecting cold mains to hot supply under sink via w/machine valves but couldn't get it working, it did however start to fill the cwsc up in the loft.
Im guessing there's got to be a blockage somewhere, any ideas on best place to start?
Cheers
Just to add, we recently changed cylinder about 3 months ago
Thanks for quick reply buddy, I will definitely try this first :)
If it's been ok for three months and the header tank has not drained out then
unlikely to be air locked.
A strong suspect would be blockage caused by lumps of insulation getting into
the cylinder when plumber not being too careful when trimming to fit the immersion
heater. This can often take months to show up.
Yeah I did consider this, the bloke I work with is pretty careful though so not 100% sure it's that
Yeah the valves are pretty old on the system, If Hoover trick doesn't work il start there I guess
Could very likely be gate valve. Hate these, i always install FB lever valves now.
What would cause the gate valve to block if it hasn't been touched? Scale?
Reply to No water from hot taps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have hot water, tank for hot water why is the hot water boiling hot from tap,and shower, We are on a schedule for hot water via our hive app...
M
Hi, I woke up this morning with cold water (mains) from downstairs tap but no hot water from downstairs tap, and no water at all from all the...
Mike Young
M
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied...
Got intermittent hot water coming the from a combi boiler to kitchen mixer tap when it hits the T junction for the upstairs bath it's hot, but on...
