Discuss Non Return Valve on low pressure system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
GGg
Previously wrote on here as the tank in the attic was overflowing due to mains pressure back flow up the hot water tank fed pipes.
Resolved this issue with a NRV on the hot pipe coming from my twin pump. (See pic)
Solved my issue but because the NRV is spring loaded the pump doesn’t turn on when I open the hot tap because the pressure isn’t enough to trigger. Either have to turn cold on the bath which activates the pump and then turn on the hot or run the hot downstairs in the kitchen which activates the pump as enough pressure.
What are my options?
Thanks.
Thanks.
Pipe it up correctly.
Negative head pump or pipe it up properly with balanced feeds
Reply to Non Return Valve on low pressure system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
