Discuss Noob question - how to remove this tap handle? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
This is undoubtedly a dumb question, but I can't get this tap handle off. I'd assumed the little insert disk would pop out but it doesn't want to. So what am I doing wrong?
https://i.*********/LAyqoHy.jpg
Alum key? The problem is the inset is domed and jammed in. Trying to insert a thin jeweler's screwdriver down the edge is scraping off the chrome plating and damaging the tap. Is there some kind of technique to this? Just pulling the head doesn't do anything (as someone suggested - sorry, no idea what "Peglers" are.)
"Pegler" is a manufacturer of plumbing parts and taps - one of the major British manufacturers.
OK - you tried to pull the top off, probably wise not to overdo trying that! Do you know what make of tap you have (it might help)?
Thanks - sorry no idea what make the tap is - fitted by someone else and can't see a brand mark anywhere. (As for Peglers - yep, but what is a set of them?!) Am now going to apply WD40 to see if that can work its magic.
Reply to Noob question - how to remove this tap handle? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
PSxxxxxx
