Discuss noob question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
pk1977
Hi
we just had a stop tap installed, in order to disconnect the water supply (because the bungalow is getting demolished).
i'd like to run the supply from the stop tap nearer the location of the new house (about 25m away).
what's the best way to do this?
I was thinking dig a two foot trench along the property boundary and use 25mm blue pipe?
then install another stop tap at the other end?
sorry, I'm not a plumber, so all this could be very wrong!
thanks
pk
Is the recently installed stop tap copper to copper?
If so are you making your joints above ground?
hi -
I wasn't there when the water company installed the new stop tap...
I was wondering that myself, and almost definitely yes (but will confirm with the crew that did the work)
No joints above ground, everything will be 750mm below, until we actually need running water...
If you intend to use this pipe to serve new property you will need it inspected by the local water company Bylaws inspector.
Reply to noob question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have just moved in to a 1934 Semi- and I am getting round a few simple DIY tasks, including a couple of plumbing-part renewals such as modern...
HI, Closing the internal house Stopcock located under the sink eventually stops water flowing from the kitchen tap or washing machine hose when...
1K
Three years ago I decided to switch from an under floor gas warm air system to a modern radiator system. I had installed a Worcester Bosch 38CDI...
Hello, This is my first time posting as I'm a new member so apologies in advance if this has been covered before. I have recently done a...
2K
Hello, Trust everyone is well and keeping safe. Apologies in advance for the lengthy post but I could really do with some advice as I'm mid...
2K
