Discuss Not happy with with new unvented system, although it works fine. Shower pressure issue in the USA area at PlumbersForums.net
What your plumber is suggesting is incorrect. You can't pump out of an unvented cylinder, you cannot also pump the cold from the tank and then have the hot supplied from the unvented.
He clearly doesn't know what he's doing, you need to get someone else in who can advise you much better.
As @ShaunCorbs says when need to know you incoming pressures, which you've been asked for a few times yet haven't provided them. You need to know these before you make any decision on what route to take.
What’s your mains pressure ?
nothing open ?
one tap open ?
I cant remeber if i'm honest and I don't have a guage. However, as i've mentioned before, pressure at the taps is perfectrly fine at the moment, when the showers are not on.
[automerge]1577373831[/automerge]
I will try to get these readings.
As for what he's suggesting, i've only wrote what I think he think he said - i could be wrong.
This is what I was going to say Pork Chop. Plumbing is not my thing but I always believed no pumps on unvented and certainly not mains hot hot and boosted cold, how would they be balanced? If at all. As we all said the incoming mains pressure and flow rates is the first thing you check before considering mains hot water.
Before I comment further can a pump be used for hot water outlets on an unvented cylinder @ShaunCorbs?
not for the outlet but you can pump the supply to it eg break tank and pump if pressure is an issue
but it sounds like flow is the problem but until we get some figures we can’t say
He told me it was measured at 1.6bar before he started the work. Not sure what it is now - need to re-measure when he is next here.
Ok when he’s here next week get him to fill this out
Pressure static (no outlets open eg just the pressure gauge open) is _______ bar
Pressure dynamic (one additional outlet open) is ______ bar
Flow static (one outlet open) is ______ Lpm
Dynamic (two outlets open) is ______ Lpm
Reply to Not happy with with new unvented system, although it works fine. Shower pressure issue in the USA area at PlumbersForums.net
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
I have just had a boiler, hot water tank and power shower pump replaced on advice by my plumber. I have two separate boilers, heat/hotwater...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
Hi, would be extremely grateful for any advice on the following. I'm installing a bathroom (shower, toilet and sink) in my summer house. It has...
