Discuss Not happy with with new unvented system, although it works fine. Shower pressure issue in the USA area at PlumbersForums.net
Non of them are correct let’s see what he says
also need them figures ?
he's just come back to me suggesting that this set up will be the one he intends to use.
What yould your suggestion be if none of them are correct?
updated diagram below.
I have looked at the Grundfos Scala2 pump you sent the link to. If I do get this, would it go BEFORE the unvented cylinder and FROM the water talnk in the loft.
Shaun - any chance of a quick chat?
[automerge]1577702731[/automerge]
I'll get those figures thursday.
You can’t pump from the outlet of the unvented cylinder (this would concern me he thinks he can do this) you sure he’s g3 registered?
would go water tanks
Pump
Cold supply to the Unvented cylinder
Cold Balanced supply to the bathrooms
Pump
I think his plumber is suggesting using the unvented cylinder as vented now Shaun!?
Pump
Really appreciate the feedback and help - I don't want to waste any more money and time.
I'm going to show this thread to him later.
Someone actually came out to check his work and a NAPIT certificate was issued?
Is the now attached what your suggesting based upon your last comment (i ask as not sure what the 'balanced' cold bit refers to)
These are the tanks he is supplying: Polytank Cold Water Tank 25gallon (UK) 690 x 515 x 520mm - https://www.NoLinkingToThis/p/polytank-cold-water-tank-25gallon-uk-690-x-515-x-520mm/10500
The file can be edited from think link via draw.io if anyone wishes to edit?
Will draw something up later
like this would be the only way i would do it
need to know your supply so can work out if the tanks are enough eg 70l
Thanks a million.
I think that all makes sense to me- apart from the unvented control block. What is that/how does it it work? Is this another unit device- rough cost?
And I see now shower pumps here- is there any way I could use this instead of the Grundfos pump as it’s at least another £400 ontop or the £700 he’s quoted me to do this week work- ontop of the £16-700 ive already paid.
Will show this to my guy and see what he thinks.
Can’t thank you enough for your input
[automerge]1577748044[/automerge]
Also, my unvented tank is 300L So think the 3 25gallon tanks = 340ish L? Should be enough?
Reply to Not happy with with new unvented system, although it works fine. Shower pressure issue in the USA area at PlumbersForums.net
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
I have just had a boiler, hot water tank and power shower pump replaced on advice by my plumber. I have two separate boilers, heat/hotwater...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
Hi, would be extremely grateful for any advice on the following. I'm installing a bathroom (shower, toilet and sink) in my summer house. It has...
