Discuss Not hot water in two outlets in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi Guys
Need to pick your brains if you have a moment.
I attended a flat where in one bathroom the hot water on the basin had major low pressure. In the Ensuite shower it was the same issue in the hot water.
All the other hot water outlets in the property had good pressure. Bath and kitchen tap.
The isolation on the basin tap has failed so I turned off the water and cut into the pipe put another isolation on it, turned on the water, opened it up and the water still had low pressure, so i figure it’s nothing to do with the tap.
The property is under mains water pressure with a combi boiler, so i can’t see it being an air lock (unless air is getting into a fitting somewhere)
Any ideas or other investigating you could recommend?
Pressure should be the same unless fed by a cold water storage cistern? If not then it’ll be low flow. Look for another restriction. Did you test the flow rate before fitting the new isolation valve?
Has the basin got 2 separate taps or 2 separate taps mixing in the spout or is it a single lever type?. If two taps are they the 1/4 turn type?.
Reply to Not hot water in two outlets in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that...
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering...
Hello All, I wonder if you can help me? I have intermittent hot water low flow from all taps in my 4 bedroom house upstairs and downstairs. I...
