Currently reading:
not sure how to bleed air from this radiator
Discuss not sure how to bleed air from this radiator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
Nobbyone
I am a handyman for a letting agent. I visited a property today to show the tenants how to bleed their radiators. But one rad had a bleed valve that I was not sure how to use. I have attached photos of the valve.
The paint from years of decorating have really bunged it up. Is it possible just to unscrew the bleed screw in the same way as a modern bleed valve or do I need to do something else in order to bleed it?
Any help would be much appreciated. Thanks
Get a 14mm socket or spanner on it. The whole plug will unscrew and you can either replace it, or bleed it like that. Keep a fingertip on it so it doesn't fall out!
Hi
It will unscrew out. Most merchants keep them. It's most probably 1/8 BSP. But could be 1/4
Bit of ptfe on the threads and that's it.
obviously make sure you've not got 1.5bar standing pressure on a combi system before you loosen it.
Loosen it while its cold so if you get a problem you won't burn your fingers regards Turnpin;)
Reply to not sure how to bleed air from this radiator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
