Discuss we have an ambirad heating system in our place of work in the Industrial Plumbing Advice Forum area at PlumbersForums.net
we have an ambirad heating system in our place of work.
one works perfectly.
if you set it to above room temperature it comes on and works fine.
the other is as if it's in reverse.
you have to set it to below room temperature for it to come on.
which as you can guess is pointless.
can anyone help??
thanks in advance!!
Could be a wiring issue, which would need an electrician, but my guess is that the thermostat / controller for the misbehaving unit has been set up in 'air conditioner' rather than 'heater' mode. This is usually a software setting and I'd expect the building manager to get it sorted pretty easily.
thanks.
Reply to we have an ambirad heating system in our place of work in the Industrial Plumbing Advice Forum area at PlumbersForums.net
Afternoon Fellas If anyone has time to help with this snag it'd be much appreciated. We have a wet-floor system controlled by John Guest UH3 and...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
So a strange conundrum regarding water temp if anyone can help resolve, would be much appreciated. Ive tried to give as much info as possible to...
the majority of my radiators have thermostatic valves. Some of these work fine but some of them dont let you adjust the temp. ie. Setting one...
Hi I am somewhat confused. My daughter has a combi boiler bought 2-3 years ago and has it timed to come on in morning for an hour and at night...
