Discuss Oil Combi Boiler Hot/Cold/Hot in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello. I have an oil fuelled combi boiler and the hot water starts hot, then goes cold for a few seconds and then back to hot... Is this right? Thank you.
Oil fired combis I think produce DHW at ~ 80C and reduce it to 60C with a TMV, if the HW from your hot tap is very hot (80C) then the TMV may be faulty and the shower(s) TMVs over compensate with cold water initially and then stabilize.
Reply to Oil Combi Boiler Hot/Cold/Hot in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
PSxxxxxx
