Discuss Oil feed pipe fire valve(s) in the Oil and Solid Fuel Forum area at PlumbersForums.net
Hy all,
Do oftec regs allow passing of the oil feed through the foundation wall under floor space if the feed pipe is installed in a fire proof steel tube? I wondered if it would help me overcome an installation problem perhaps with a fire valve at either end of the feed as it enters and exits the wall?
Can’t picture exactly what you mean.
I have on occasion run an oil line in the screed through a steel sleeve, with the kbb capillary in a separate sleeve (in case of need for replacement).
Hy D, Its a simple bungalow with boiler on wall opposite to the wall where the pipe enters the property under floor level. I wanted to run plastic from the tank at 450mm deep up to the firevalve 7M away from the boiler on the opposite side of the building. Can I run the feed in copper from the firevalve up to an internally mounted GOK deaerator or would the feed have to exit to another firevalve on the opposite wall where it would technically re-enter the building? Hope thats a bit clearer..thx for reply.
Dov
Reply to Oil feed pipe fire valve(s) in the Oil and Solid Fuel Forum area at PlumbersForums.net
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented...
1K
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler...
… praying to the plumbing God, Bob Pictures and layout details attached, so be patient. 21 year old oil fired system in pretty good nick. I...
1K
I'm a plumbing novice so first of all I apologise if I'm not explaining this situation correctly. I've recently renovated a house for my family to...
2K
Ok I have been dealing with this problem for over a year and finally have to ask for some help as backflushing every 2 weeks or so is getting very...
1K
