Discuss Old Grohe mixer tap knob removal in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I need to replace the washers on this old (1980s?) mixer tap.
Can anyone tell me how to release the knobs on these? It looks like a 4-way spring-action plastic clip and I can't feel anything like a screw in the bottom of it.
Many thanks.
Just guessing but what about pushing socket or suitably sized piece of tube onto the tapered ends of the plastic clip. Might push all four in at the same time so you can slide the knob off.
Thanks for the suggestions chaps. I've pulled hard but there's no budge. I wonder if I need to make up some sort of pullers?
I suggest you try squeezing one or two of those plastic clip parts using pliers or similar, while gently pulling the tap head out towards that side
Reply to Old Grohe mixer tap knob removal in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few seconds! Can anyone tell me what is causing this? And how to cure?
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
