Discuss Old radiator fittings. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Somebody wants me to change some thermostatic valves on old radiators. They have old thermostatic valves already but the fittings are not standard. The pipes are 15mm but the valves are much bigger, the tail in to the radiator is a few mill bigger with a bigger nut to the valve, the valve is much bigger and then there is a reducing fitting to fit the 15mm pipe. Anybody know what size this is and if you can get replacement fittings?
Thanks Mick
yes they are standard fittings 2 types and usually come with the tails that go into the rad take a pic on your phone and go to a local merchant not plumbase or plumbcentre , If you take one of the valves off you maybe able to replace just the valve with out touching anything else depending on the make good luck
The problem is that the old tail is bigger than the new tail, the nut that normally screws on to the valve is also bigger than the standard 15mm nut.
as i said before you may get a straight replacement valve depending on make which will be a straight swap over just unscrewing old valve and putting new one on
The problem is not getting the old ones out, but that they are bigger than standard fittings. I cannot take one out and take it to the plumbers merchant as the customer wants to know how much it would cost first. I know I can ask at the plumbers merchant do they have any bigger radiator tails for valves but was just interested if anybody knew of bigger types and their measurements.
I will ask the customer if he can send me one. It is not that close and not a big money spinner so not worth me going over to take a photo. Will post a photo if he sends one.
Sounds like you have the old 1/2 inch threaded type. Check out Danfoss or Honeywell commercial TRV's. These are sometimes twice the cost but if you want a straight swap then this is the only way.
They may be 3/4 valves. Depends on how old or what type rad. Take some bushes with you.
From what everybody says they I think they must be 3/4" valves, is there any way to reduce the fitting into the rad down to a 1/2" for a standard radiator tail or is it best to find some 3/4 valves?
Empty the radiator, remove the 3/4" fitting and fit a 1/2" one. The part of the valve that goes into the radiator is always the same size, the outer part is either 3/4" or 1/2".
Reply to Old radiator fittings. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
