Discuss Old TRV Valve connection in the DIY Plumbing Forum area at PlumbersForums.net
I have a tiny leak coming from the underside of the "nut" at the top of the copper feed pipe on an an old Valiant TRV valve . It probably just needs a tightening or a bit of PTFE . I understand that these are usually compression fittings but I think this might be something different as the way it is attached looks different to the more modern TRVs in the rest of the house. I don't want to start trying to force anything without understanding how this valve is attached to the copper pipe. Can anyone advise? Cheers
Reply to Old TRV Valve connection in the DIY Plumbing Forum area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
