bythesea
Hi all
its that time of week again where ive gotten stuck on a job and could use your thoughts...
flat is in an old folks home all rads piping hot apart from one in living room.
. The pipes to the thermo valve and lockshield were cold when i first arrived altho the vavlves turned on. I took the rad off, emptied and got loads of black water out of it. I opened the valves until water ran hot which it did on both. piping hot like the other rads. I reconnected rad opened it all back up and the rad was nice and hot. Problem was 10 mins later luke warm at best and pipes were cooling.
am i missing something easy? I thought as the water did come through hot that changing the valves wouldnt change anything? There is no boiler in flat as fed from a boiler room which is far away. system must have been vented as was topping self up
so I failed after 2 / 3 hours of messing about. Any thoughts?
