Discuss one stone cold radiator in the USA area at PlumbersForums.net
Hello everyone looking for abit of advice I've got a total of 6 radiators in my house 5 are all hot but the and 1 that is stone cold ive checked the trv pin and it doesn't seem to be stuck ive bleed the radiators and hasn't done nothing I turned all other radiators valves off on both ends of radiators and the 1 that wasn't working gets hot when the rest is turn off I had a new boiler fitted along with 3 new radiators fitted the radiator that is cold is brand new less then a week old along with boiler was all working until I turned heating off yesterday and when I turned it back on that 1 particular radiator didn't get hot looking for some help or advice has its cold in living room without it many thanks in advance
If rad is working with others turned off probably a balancing issue.
As your boiler is only a week old get installer back as system needs correct balancing to work at its most efficient.
Reply to one stone cold radiator in the USA area at PlumbersForums.net
PSxxxxxx
