Discuss Only getting hot water from bath tap no where else. in the USA area at PlumbersForums.net
I have what seems to be a unusual problem and hope can get some advice. I have a bathroom up Stairs, and a wet room down stairs with toilet and sink, plus sink in kitchen. We have a solar hot water system and gas boiler, it's the type where water goes up to loft through solar panel where it is warmed up then goes back down stairs to a tank in cupboard it kitchen, next to this tank is a gas boiler that heats water up if not hot enough. I hope that makes sense.
Okay so my problem is I can get very hot water from bath tap in bathroom up Stairs, but I can't get any hot water from bathroom sink tap upstairs, bathroom sink downstairs or kitchen sink. It's just cold no matter how long you leave it running, occasionally it will go hot for a few seconds but it will then go straight back to cold. It won't stay hot, other times it won't get hot at all.
It all started after kitchen tap broke ( end of tap fell off) so had to replace tap. We definitely got the right type of tap, we have tried replacing tap thinking. There might be a fault with new tap, but still the same problem. I've tried turning off cold water going to kitchen tap as a test but still no hot water, I tried this on the other sinks to but again no hot water.
Could changing that kitchen tap have affected all sink taps in house or is this just a coincidence.
Also all thought we can get really hot water from bath tap it does drop out and go cold every few minute for a few seconds and it goes cold, making running a bath harder and having a shower impossible as it will be hot then suddenly go cold. This was happening before problems with hot water from sink taps.
Any one have any idea what the problem could be and how to fix, is it most likely the solar system or boiler or could it be kitchen tap causing problem
Any advice much appreciated
Thanks in advance
Can you isolate the water into the cylinder eg the cold feed to it ?
Turn this off then open your bath / the one that works confirm it stops
Now try your problem ones and report back
Sorry it has taken me so long to reply, I've been very ill. My boiler is a Alpha CD25X. I've attached some photos of boiler. Still having same problem. Had problems with bath tap not getting hot water either now, but water still gets hotter from bath tap than from any other tap.
The weired thing I've noticed recently is that the problem is worse in the Afternoons and Evening than the mornings. In the mornings I can get some hot water but it comes and goes. But Afternoons and evenings you can't .
Any ideas as to what's wrong, Another thing I forgot to mention is just before we started having this problem with getting hot water, I turned on hot tap it made a strange sound and then black water came out. Of tap for a bit before going back to clear. Since then we have had problems with getting hot water.
I am waiting for boiler engineer to come out again to look at boiler they are due to come next week. But want to make sure it isn't something obvious before I waste money on boiler engineer. And want to try and get some idea of what's wrong incase they try to fob me off again.
Thanks again for your help and advice
Reply to Only getting hot water from bath tap no where else. in the USA area at PlumbersForums.net
I live in an apartment with a cold water tank. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I refurbished my...
We have hot water, tank for hot water why is the hot water boiling hot from tap,and shower, We are on a schedule for hot water via our hive app...
The Water Board have just replaced the main water supply to our property. We have a ground floor combi boiler. The central heating system for the...
M
Hi, I woke up this morning with cold water (mains) from downstairs tap but no hot water from downstairs tap, and no water at all from all the...
Mike Young
M
