Discuss Only one working radiator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all,
I was hoping someone could help me solve and repair my central heating issue.
Only a single radiator works in the property in the bathroom.
This room is located directly above the boiler on the first floor. The boiler is located within the kitchen on the ground floor.
I notice when the boiler fires up the pump says 1 watt, then a few seconds later has two dashes.
All the other radiators are stone dead cold.
Any ideas?
Correction-
A second radiator in the adjacent bedroom is warming up, to include its outlet pipe.
The third radiator in the second bedroom is cold, but notice the inlet pipe is luke warm. The central heating system has now been on for 30 minutes.
When I tested the system in Winter 2016 only one radiator got hot, so a little improvement since then for some reason.
Chris.
Take the trv heads off and does the pin push down ? Also lift it till it stops don't force it up too much you should have heating
The only reference I can find to the 2 dashes shown in your pic is here:
http://us.grundfos.com/content/dam/GPU/Literature/ALPHA2/99187617_0217_ALPHA2_IO_Internet.pdf
It seems to be an indication that the supply voltage is too low.
Whether that's normal when there is no call for the pump to run I don't know. Hopefully someone else on here has more experience with this particular pump.
The fact that only one rad upstairs above the boiler is getting hot indicates a pump problem most of the time. Your boiler may also lock out during calls for heating because the hot water isn't dispersing quickly enough.
Doesn't look like you have access to check the return pipe temp while it's running.
I'd say most people would need to call a heating engineer in this situation.
Try this
Press and keep pressing the grey arrow point so it fills the II mark
That's fine there lockshield valves won't go wrong unless there shut (anti clockwise to open if your wondering) but if they've worked before leave them point to either controller not giving power to the pump or duff pump
Do you have a multi meter?
Could be the bathroom radiator is on the hot water primary circuit with either central heating not called for or a duff motorised valve.
I've never turned those off and the system used to work fine.
I don't have a multimeter unfortunately, would that be to check the power to the pump? I am wondering whether I can try and turn the pump manually to see if it's siezed but don't see a screw on the front to get access?
That's fine
And yes to eliminate the programmer any chance of another pic close to the bottom of the cylinder/ can you see a port valve
Like in the pics below?
Yes can you hear that moving (should click and pump turn on)
That's it, I would say pump but without checking the voltage to the pump can't be 1000% sure
Is it worth checking whether the pump is seized?
The only way with the erp series is to take the pump out completely, there's not a manual air vent like the old series used to have
Ah that's a shame. Oh well if im.takibg the thing off I may as well replace it! I've found a you tube video explaining how to replace, but I'm guessing I'l need to drain the system down as I can't find the isolation valves to the pump itself.
Yes and replace the pump valves as there the type to leak if touched
Can I suggest before ripping it out disconnect the pump supply and put it on a plug and extension lead to try it. it wouldn't be the first time I've found dodgy switch contacts meaning the pump isn't getting voltage.
I may get someone to do it for me as there seems to be a lot involved. Can't find a drain valve now. Any ideas of what I should expect to pay for this?
But then the display wouldn't light up ?
And op your best having a few plumbers quote
Basic version: dodgy contacts can cause high resistance. When the pump is off load the voltage is high enough to run the display. When the pump load increases the resistance causes the voltage to drop. LED displays don't need much to run but motors do, hence the 'fault'.
Has no one noticed that the pump valves appear to be in the
closed position?
Reply to Only one working radiator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
