Discuss open fire and oil boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
CXR100
is It possible to connect to a open fire already installed to feed gravity hot water and pumped heating , a conventional oil boiler boiler, its in my own house, never done it before , asked some other plumbers and they said that you can do it with a 3 port valve , there must be a way to do it. can anybody help me out. thanks
Strange for any plumber to say use 3 port valve! You have a gravity circuit and a pumped circuit.
The Dunsley neutraliser is what it says, - a neutral point for gravity circuit and pumped. Just need gravity circuit from fire joined to the Dunsley unit and the oil boiler pumped pipes and exiting pipes also joined to other tappings.
Or you can use a twin coil cylinder. This will mean the gravity coil and the pumped coil are separate. Then the only circuit you connect is the pumped radiator circuit, but using a check valve at each boilers pumped pipes to avoid one boiler heating the other and also resulting in bypassing
Thermal store system far preferable to twin coil cylinder
Reply to open fire and oil boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Hi all, I am a plumber but I do not carry out works to boilers as the majority of my is bathrooms so I am not gas safe. I have completed a...
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler...
Hi, Over the past few months, my wife and I have noticed a constant pulsing sound throughout the house which is particularly noisy at night (this...
Hi, I am replacing our 11 year old boiler (due to H.Ex. leak) with a new one. This is in a "sealed" system with red expansion vessel in airig...
Hi, Newbie here so feel free to teach me the etiquette of this place, and apologies for the lengthy opening post. The boiler started locking out...
