Discuss Open vent heating system - Vent discharge in the Central Heating Forum area at PlumbersForums.net
Timmy D
Subscribed
Got to look at a system which is discharging out of the open vent.
Any tips, hints?
Gonna check f&e/pump connection locations.
Pump speed.
System water quality for indication of blockage.
Worth cutting out the feed tee to check for blockage?
Any others?
Assuming someone has not stuck in a 7mt pump running flat out check
pipework layoutI
If its pumping over and water going straight back in system probably cold feed clear.
Reply to Open vent heating system - Vent discharge in the Central Heating Forum area at PlumbersForums.net
PSxxxxxx
