Discuss Pipe bending help? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Matthew Piper
hello. i'm new here, and new to plumbing.
for my course i have been asked to work out the exact length of a 45/135 degree bend in 22mm copper. and do not have a clue how to work it out.
i've been given 2 measurements : 275 and 300 each side of the 135 bend. whats the total length of pipe?
Your straight lengths are 275 and 300 as you state. 45 degrees is 1/8 of a full rotation therefore the section of the bend is (1/8) x 2 x pi x r where r is the central radius of the pipe bender specific to the bender.
Yes I know thats what everyone does in the field but students have to know how to calculate pipe lengths.
The radius is sometimes marked on your pipe bender. This radius and hence the overall length of pipe will be specific to your make of pipe bender, but there is proabably a standard value that the college will give you for doing calculations.
The colleges sometimes refer to something called "gain". This is the difference between the length for the straight sides and curved segment, and the linear measurements to where straight lines continued from the straight sides bisect. Basically when pulling a bend, the pipe "cuts the corner" and this value is the difference.
Don't worry, you won't need to make single sections of complex bends in different planes in real life (unless you are doing heavy gauge steel). The only trades who do this are the car exhaust fitters.
From a fluid mechanics point of view, slow bends are always preferable to elbows as greater hydraulic resistance is encountered the sharper the bend. The friction losses to head are hence greater.
See description:
Simulate hydraulic resistance in pipe bend - Simulink
As regards to bending, we work on the assumption that the plastic deformation is equal in compression and expansion and hence take the centre line of the pipe as the neutral, undeformed plane.
Bend radius (on the neutral axis / midline ) is usually 4x tube dia, for copper, but benders vary from model to model.
See description:
And it looks better and shows a bit of skill
what a load of bull you will never use these calculations on site. So why teach them
i agree theyd be better of teaching some use full stuff most boys who go into the building trade tend to be practical rather than theory boys theve struggled at school to keep up with maths and science then the go to colledge and get more useless theory stuff slung at them
i spent half my time at college doing back gutters in lead ally and neualite and pulling 4 inch nends despite roofing having already become a seperate trade and 4 inch lead being obsolete in this age of infomation interchange youd hope the college would have caught up
Reply to Pipe bending help? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
