Discuss Pipe bends in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Stokesy11
Hi guys,
was as just interested to know what pipe bends do you find you use most on site?
I only ask ask as I been practicing my 90 degree, offset and crossover at home before I start my apprenticeship next week and having lots of fun doing then and have to say getting quite good.
someone said to me about bridges which I have t been shown before and I wanted to know are they used a lot or any tips how to do one?
much appreciated.
Here's a link to the UK Copper Board where you can find lots of useful information on working with the best plumbing material around.
Home | Initiative copper
When I signed up a few years ago they also sent me a good manual on pretty much everything you need to know about copper installation. It has a detailed section on bending too.
Reply to Pipe bends in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I will need: install new 100mm pvc pipe work, 90-degree bend for new W/C install new 100mm pvc pipe work, 90-degree bend with new gully pot at...
Had a collapsed/cracked collar on the 90deg angled piece that my soil pipe sits in which is leaking water so has needed replacing. Access has...
I had an outside tap fitted by a professional plumber last autumn. During the recent cold weather the feed pipe under the kitchen sink froze and...
Hi All, I hope you are doing well. I have this 3.25mm lead-free grade 99c solder wire. I know that the good practice to bend the wire before...
Hi, came across this old push fit waste pipe. Stripped out the old shower and it was a 40mm waste pipe siliconed in the fitting. The fittings at...
