Discuss Pipe centres for shower too wide in the USA area at PlumbersForums.net
I had a plumber start the renovation of my bathroom but he had to be dropped off the job for making several mistakes.
He has fitted the bath and loo, but not the shower nor the basin. He has done the pipework for the shower. Chased the wall out and used 15mm copper pipework. Wall has been tiled, leaving the two pipes exposed to fit the thermostatic shower bar valve. The pipes are 15mm, and the shower valve is 22mm feed, so there will need to be reducing valves used; this is fine.
The challenge now is that the pipe centres are 160mm but the shower valve is 150mm. He's obviously mis-measured. Tiles are done. My father and I are attempting to finish the job, but not sure what can be done to remedy this mistake and compensate for the extra 10mm. There is some give, but not a lot.
Any advice that doesn't involve smashing the tiles!?
Betz
So, in the description on the link, it states adjustable centres 135mm to 165mm, surely this will fit?
Hi. Yes that will fit.
It's just that in his original post, the OP mentioned a "thermostatic shower bar valve", from which I assumed he already has the mixer he wants to use.
Apologies if that's not the case.
If it's a thermostatic bar mixer then use a fast fit kit. Nibble at the tiles with a small masonry drill bit on the insides until you gain 5mm on both sides. The fixing kit will cover the holes you make. Also a quick squirt of clear silicone into the holes to seal it up.
Reply to Pipe centres for shower too wide in the USA area at PlumbersForums.net
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes sunk into wall behind bath. Walls have fresh tiles. Have realised as about to fit shower these pipes one is set higher than the other. If you fit a...
