Discuss Pipe Hammer Increasing in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Recent hammer started to get violent. 30yr old extension retained galvanised pipe riser to 1st floor and an unvented hot water cylnder installed (no header tank). No problems until last 9 months or so when pipes began to hammer on turn on/off taps/cistern (grnd and/or 1st). Recently this has become fierce and seems to go back along to the vertical riser. Source appears to start at or be much reduced when these fittings (on the cold supply) are lifted: Does it have anything to do with this part? Is there any maintenance that is required? Puzzled why it has so recently developed.
263.3 KB
Reply to Pipe Hammer Increasing in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking?
This originally happened about 12 months ago and has happened 3-4 times since.
It’s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
Hi all I'm hoping someone can shine a light on this for me
Since our stop tap on the pavement has now been filled with sand for whatever reason, we are relying on our property fitted stopcock (this is outside on our garage wall)
Unfortunately turning this to the closed position only reduces...
