Discuss Pipe insulation & different types in the USA area at PlumbersForums.net
Wrong drain off should be long stem type then you would not have that scruffy bit of soldering.
Holds water but any decent engineer looking at it will always think what?8
They look like flow and return pipes. You may need to use both as the water in the top pipe will probably have no way to get into the lower pipe in a draindown situation (this is normal and is probably why 2 valves have been fitted.).
Reply to Pipe insulation & different types in the USA area at PlumbersForums.net
