Discuss pipe size question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Matty A
On a gravity fed system would it make a lot of difference to the flow pressure to the bath taps if the pipes where reduced from 22 to 15 for the last meter or so?
Also is there any way of increasing the pressure to both hot a cold feeds with out the use of a pump as i have a customer who complained of the reduced water flow to her bath hot water so i suggested putting in a single end shower pump which i installed on friday she is now saying the pump is too noisey and wants it out but i should also add that she has a fancie shower with normal shower head and one of those large rose thingies which she got off EBAY.
The pump fitted is the Techflow QT-45..
its better to have 22mm mpipe to the bath taps, where did you put the pump????????, the shower sounds like a diverter valve and would be better if it was used with a combi boiler, it may use more water than a gravity can supply
Cheers for that mate i sorted it today i up graded the pump to a twin impellor and boosted both hot and cold.
I put the pump infront of the cylinder in airing cupboard and it has its own seperate feeds both hot and cold this has worked fine. As for the noise it was just vibration which i sorted with some loft insulation taped to a piece a ply and placed under the pump.
I also changed the bath taps back to 22mm it has made a little difference but not much.
Ah man I have just sorted out this type of thing.... well what someone else had messed up anyway.
Here is my advise....
Firstly you should in my experience us a twin impeller pump as you have done. However, you should always read the manufacturers instructions BEFORE installing the pump. Mostly you will find that the pump must be located next to the DHW tank, connecting via either a surrey or essex flange on the tank.... as per the install instructions. The reason for this is that it will not then void the manufcturers warranty.
It sounds like you have the pump mounted in the roof space and it is/was sitting on the loft boards... therefore creating far too much noise...:confused:
Really the pumps sould be located next to the DHW tank and running the suggested "at least" pipe size according to the install instructions etc etc.
Hope that helps :rolleyes:
if you read pump instalation instructions you will also see that most pumps must not be used with temps over 65 degrees c
Yeh, to be exact... the regs temp for a DHW cylinder is between
60deg - 65deg C.
Reply to pipe size question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
A
Hey, here goes and I hope it works.. never used one of these before! I have a Sagittarius Ergo mixer shower min bar of pressure required 1 bar...
Hi, I hope someone can help. I’m hoping this isn’t a permanent problem. We’ve converted a gravity vented hot water system, into an unvented...
1K
