Discuss pipework replacement - good/bad idea? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
woodenhousejen
I am upgrading a house (wooden frame, wooden clad, brick base - old forestry style).
The plumbing and heating needs replaced (currently electric emersion and open fire back boiler).
The pipe work that is in is 8mm external diameter.
I know the current trend is to increase the bore of pipe work.
Would it be worth the time and financial investment to replace the small bore I currently have with an increased pipe bore?
Any advice and/or peoples thoughts about this would be greatly appreciated.
J :)
PS not sure of the lingo so if the above is unclear please ask for more detail....
It is probably junked up so if you are doing a major overhaul worth while. By the time you butcher it about to alter it, it would of been easier and quicker to fit whole new system.
Reply to pipework replacement - good/bad idea? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I live in a small 2-bed bungalow, with a relatively new Worcester Greenstar 30Si Compact combi boiler running 7 radiators. The radiators...
