Discuss Pipework type / design for Unvented Cylinder ( 170 L Megaflo Eco ) in the Central Heating Forum area at PlumbersForums.net
Hi I'm tying / hoping to run a drain for an Unvented indirect cylinder
I need to run it now as I want to close in the building ( its in a loft conversion )
I'm having great difficulty getting someone to fit the whole system
for me , it was being done by a guy but now he can not do it as hes moved away
I'm trying obtain new quotes ( everyone's busy )
Ive been told this so far
run it in 40 mm pipe and bring it up where the cylinder is
found a sketch online is this what I need / current regs ?
also is it polypropylene pipe
The run is 3.5 Mtrs straight then drops down through soffit elbows left ( swept bend ? ) into soil pipe 700 mm
Thought you found a new guy to do the install ?
but it needs to be 11/2 push fit with swept elbows and clips every 450mm
I have had a guy round to quote but was a little bit bolshy and said just put a 40 mm pipe into the where the cylinder is and wouldn't elaborate , I thought there would be a little more
about the discharge pipe if I put a diagram would you have a peak ? as Im not sure I understand your reply
Yes post one up
Yes post one up
Hi Shaun I've not done a diagram yet but have been doing a lot of reading ( dangerous I know ) but this is what I've gathered from yourself and others does this sound ok
The discharge pipe D2 from the self sealing waterless valve ( as shown in the diagram above )
then a swept 90 bend
a 3.3 Mtr run clipped at 450 center's
two 45 bends to achieve a drop down through the soffit to vertical
a 250 mm verticle drop
another 90 swept bend
then 600 mm into the stack
this would all be in 40 mm black or white pushfit fittings in propropylene pipe
then only thing ive found that this would not work as the pipe work goes outside and ive read
propropylene .,s not suitable oustside as its not UV resistant
other than that I've read it could be done in 22 mm copper copper but then I cant find a suitable boss connector adapter any ideas
Tbh it doesn’t harm it that much the uv rays there loads of push fit used externally as most of the diy places sell it
would need to be in 28mm copper due to distance
but in essence what I've described is ok regarding the description of the run im doing is ok in 40 mm pushfit ?
on the copper side of things the total run is 5 mtrs max ( probably less ) and thats not suitable for 22 mm ?
40mm is fine
Correct 28mm is required just as each elbow adds 1 m total for 22mm max is 9m so if you have 4 elbows your over
ah ok so if i go up too 28 mm copper could i use one of these to connect into the soil pipe
https://www.NoLinkingToThis/p/pegler-brass-compression-flanged-tank-connector-28mm/1963g
it could go into the outlet on the bossed access ive got already
hmm just thought it would need to be curved to fit contour of pipe
No that’s for a tank also the g3 engineer needs to do the work
Reply to Pipework type / design for Unvented Cylinder ( 170 L Megaflo Eco ) in the Central Heating Forum area at PlumbersForums.net
Hi Everyone, Hoping for some advise / assistance on an issue I have on my Megaflo Eco System Unvented Cylinder which is making a loud band...
2K
Hi, I live in a 9yr old 3 story townhouse with showers on the 1st and 2nd floor, a bath on the 1st and toilets and basins on all three floors...
2K
Hi, some professional advice would be greatly appreciated, We are having an Unvented Cylinder installed into our 2 bedroom ground floor flat. I...
9K
Hi all, We moved into our current home 18-months ago and the following heating/ HW system was already in place: Worcester Bosch 24i system boiler...
8K
I
  • Locked
Hi all, new here. I am in the middle of researching unvented direct cylinders to replace my faulty cylinder at home. A bit of background...
im4gine
I
